Custom Shadow map from an image
how do I add a
custom shadow map
from an
and how to access
window.sdApi.scene.getBoundingBox() in version 3
Hello @Muhammad_waleed_akht,
currently there is no way to add a custom shadow map and it is also not in our pipeline. What you can do is adding a plane that has a map with transparency applied. See here: gemstones (simple) - envMap change - CodeSandbox
Regarding the bounding box, you can call sceneTree.root.boundingBox to get the bounding box of the whole scene.
Cheers, Michael
