Custom section style don't show up on capture viewport
this is what i see…
this is what i get with capture viewport.
layer is red, so section is red, not like in the preview of the View capture settings
@enzo_molinari I’m not seeing the problem at my end.
Can you please include a file and what version of Rhino are you using?
Hi!
Same problem. Maybe there are some solutions?
Can you please include a file, steps to recreate issue, and the version of Rhino you are using?
Of course. I’m using rhino 8.6.
There is custom section in vewport
There is section in captured view
I want graphic in captured view just like in viewport
2024.08.05_(mcneelforum)_01.3dm (13.8 MB)
Can you update to the latest Service release and see if you still see the problem?
Also, what Display mode are you using?
This is what I get using 8.9
Usually Technical or Shaded mode, but no matter
I’ll try to update rhino
I have installed rhino 8.9 and increase custom section scale, an it works. Thanks a lot!
But in some places in the section there is still no solid hatch. In viewport all section are grey, in captured view only some of these. (Captured view outline added by me in the indesign, it’s not relevant to the matter)
Also i dont know how to increase hatch
thickness.
Do you know how to fix this issues?
The display can create a fill, but this might not be a SectionStyle setting. Does your window grame object (or layer) has a section style set up with Solid Hatch?
The SectionStyle currently does not have a thickness property for hatches, so if you need to control that, set the PrintWidth option to by “ByLayer” so you can update the output layer of the section hatch to your liking. Does that help?
