Is it possible to display a custom object Parameter (Cost, Finish, Fire resistance, Manufacturer…) inside the tag ?
It’s OK for the Name, Tag, Area… but I don’t uderstand the syntax for my custom parameter.
Thanks.
Adrien
Thanks.
Adrien
Hi Adrien,
This is not currently possible now, but it is planned for the future versions.
I’ll let you know when we implement it.
“Custom Parameter text inside Tag object” would be something I really appreciate.
Hi @zakxxi, @ahmet.unveren the new VisualARQ 2.11 includes the option to display custom parameters in tags. In order to do so, you need to write the following syntax in the tag content: %<element.parameters[“ParameterName”]>%
Check this out in the following example.
Find more information of VisualARQ 2.11 here: VisualARQ 2.11 available - VisualARQ
