Custom mesh grips unable to transform object
Hi @dale and all,
I made a custom mesh grips with custom user data, similar to your rectangle one.
Though, something doesn’t work: when dragging grips, OnDraw() properly draws a dynamically modified mesh, but at the end of a grip drag the original mesh is not replaced. A line in the command prompt appears: Unable to transform 1 object.
It seems as if NewGeometry() is not giving a proper mesh, but I really think it does. I’m struggling with this, as the code is very similar to a plugin with polylineCurves and custom user data that works.
Is there something when going from polylineCurves to meshes that I’m missing?
Many thanks!
Pablo
Before returning a new mesh, check to see if is valid:
bool bValid = mesh.IsValid;
To find out what’s wrong with the mesh, you can do this:
string log;
if (!mesh.IsValidWithLog(log))
  RhinoApp.WriteLine(log);
  return null;
I checked to see if the mesh is valid, and it really is valid! I also checked that is has user data, with mesh.HasUserData.
I’m quite surprised, I didn’t expect it. I don’t understand why it’s unable to transform the mesh, if NewGeometry() is providing a valid mesh for any drag.
Do you have any other suggestion?
Thanks a lot,
Pablo
Hi @dale,
I attach here the sample that is giving me problems, in Visual Studio.
SampleMeshGrips.zip (35.2 KB)
I made it from the rectangle grips sample to work with meshes. It just freely modifies the vertices of a given mesh.
First, create a sample mesh with the command “SampleMeshGripsCreator”, then edit it with “SampleMeshGripsModifier”. In wireframe mode, the original mesh is in black and the dynamically drawn mesh is in red. Drag a grip and check if at the end the black mesh is replaced by the red mesh or not.
In my case it’s not replaced, and the message “Unable to transform 1 object” appears. I have Rhino 5.13 for Windows.
Please take a look and tell me what happens. I would highly appreciate if anyone else tried too.
Many thanks,
Pablo
This is definitely a bug. Unfortunately I won’t be able to fix this in Rhino 5. Any fix will go in the Rhino WIP.
https://mcneel.myjetbrains.com/youtrack/issue/RH-36059
– Dale
A fix should be in next week’s WIP release.
– Dale
Many thanks! I’ll go for the WIP then.
Pablo
Fixed in Rhino WIP 6.0.16306.09301, just released.
