Custom Lighting: Confusing and one feature might be broken
TLDR: I kind of got things working but it feels broken. It would be nice if there was some guidance on this. I cannot find the help section on this just an old post.
Custom Lighting has me a little confused. And also the “Use current scene lights” doesn’t seem to do anything.
The axis’ feels both backwards and switched around. It’s hard to tell where the reference is. Two of the values feel backwards and two of the values seem like they’ve been swapped. I did get what I was looking for (kind of).
I’m more or less trying to create this lighting from all four directions. And have a display mode for each of them. Simple as this:
I’ve sort of got what I was after but I’d like to have a little more insight into what I’m actually doing.
I also had to do a bit of trickery to get an RCP to work. The lighting seemed to prefer a saved view or else it came in all dark. It looks more or less like I wanted but I have a feeling I’ll be adjusting the angles a lot in future projects.
To summarize this post: I can’t find the official help documentation on Display Mode Custom Lighting, and the “Use current scene lights” button seems like it’s dead/disconnected.
Hi Keith,
Agreed on your comments. I was trying something similar a few weeks back, trying to recreate a revit / archicad like hidden line display mode with shadows. I couldn’t quite get it right.
But I did find the documentation - Custom lighting is referred to as Lighting Scheme in documentation
Is that what you’re looking for?
Cheers,
Stuart
It definitely helps! I felt my way around with the XYZ direction I kind of get what was going on. Basically I have 4 display modes and I can pick the angle that best conveys the geometry. I had to make 4 more modes for RCP’s too.
It’s starting to look pretty good but I need to sort out the linework a bit. The shadows are close tow where I want them.
I could post the display modes if you want.
Cheers, please post. I’d be interested in having a look.
I should almost just post screen shots. Actually let me know if you prefer that. That might be quicker and easier to apply to your own display modes.
kCs-SD1.ini (15.0 KB)
kCs-SD1-RCP.ini (15.0 KB)
kCs-SD2.ini (15.0 KB)
kCs-SD3.ini (15.0 KB)
kCs-SD4.ini (15.0 KB)
