Hello-
I need to speed up my workflow. I make custom millwork, and usually use Rhino for designing it. Typically I will make ‘Shop Drawings’ in 2D, then flesh those drawings out as needed. If there were a way to perform Offset
in a slightly more sophisticated way, it would make this task immensely easier.
For example, take the following drawing:
If I could Offset
the rectangles that comprise this drawing on specific sides, all final door sizes could be derived, like so:
For instance, if I want a 3/32" reveal on all panels, many of them will have a 3/32" offset on some sides, and a 3/64" offset on others.
if Scale1D
could be performed not as a total value but rather a change in value, it would be similarly useful for me. For instance I could select a number of rectangles and shrink them all by 3/32" on the right and left sides. From there it is a simple matter of extruding those curves into 3D and adding a few panels.
Are there commands that I don’t know that would get me closer to this workflow? The frequency with which I am using these two commands points to a better way…
Do I need to go to Grasshopper for this functionality? I’ve used it in the past for more complex mechanical design and perhaps thats the best route, though something simpler would be ideal. Not opposed though.
Should I not be designing kitchens in Rhino, or at least not making my shop drawings to build from in this program?
I love Rhino, and would like to stay in this software if possible / practical.
Thanks for any suggestions
Revel
ridge_shops_03.3dm (1021.9 KB)
