Custom grips for SubD crashes Rhino
We are creating some custom girps for SubDs and it seems that every time NewGeometry() is called Rhino crashes. Is this a known bug?
Thanks
Alberto
Not that I know of or can find. It would be best if you can send sample code that we can run that shows this issue.
Hi @Gijs ! Thanks for the reply
please find here a sample project with a single command. If you run the command on a SubD and try to edit it a couple of times you will crash Rhino.
SubDCrash.zip (93.1 KB)
Let me know if you need any further input from my side.
@dale can you help with this?
Hi @Alberto,
I’ve logged an issue so I can remember to look at this.
https://mcneel.myjetbrains.com/youtrack/issue/RH-74221
– Dale
Thanks a lot, would be great to have it working!
