Custom Grasshopper button error
Hey everyone,
I am trying to develop a custom button for Grasshopper through the Grasshopper add-on in Visual Studio 2010. I am using Rhino 5 and Grasshopper Version 0.9.0056.
The script works in the custom VB.net function. The script also has no errors within Visual Studio. However, when I build the button and use it in Grasshopper, it error’s: invalid cast: integer>>Double. I have double checked the script and there are no instances where an integer is dim as double or used as a double.
Here’s the Script:
Imports System.Collections.Generic
Imports Grasshopper.Kernel
Imports Rhino.Geometry
Public Class Mesh
Inherits GH_Component
Public Sub New()
    MyBase.New("Mesh", "M", "Mesh Object", "Mesh", "Mesh")
End Sub
Protected Overrides Sub RegisterInputParams(ByVal pManager As GH_Component.GH_InputParamManager)
    pManager.AddMeshParameter("Mesh", "M", "Approximation Mesh", GH_ParamAccess.item)
    pManager.AddSurfaceParameter("Surface", "S", "Surface Being Approximated", GH_ParamAccess.item)
    pManager.AddIntegerParameter("Weight", "W", "Slider determining the amount of movement", GH_ParamAccess.item)
    pManager.AddIntegerParameter("Iterations", "I", "Slider determining the number of iterations", GH_ParamAccess.item)
End Sub
Protected Overrides Sub RegisterOutputParams(ByVal pManager As GH_Component.GH_OutputParamManager)
    pManager.AddMeshParameter("Mesh", "M", "Approximated Mesh", GH_ParamAccess.item)
    pManager.AddVectorParameter("MovementVector", "U", "The movement vectors of the mesh vertices", GH_ParamAccess.list)
    pManager.AddPointParameter("Vertices", "V", "Mesh Vertices", GH_ParamAccess.list)
End Sub
Protected Overrides Sub SolveInstance(ByVal DA As IGH_DataAccess)
    Dim mesh As New Rhino.Geometry.Mesh
    Dim surface As Rhino.Geometry.Surface
    Dim weight As Integer
    Dim Iterations As Integer
    If (Not DA.GetData(0, mesh)) Then Return
    If (Not DA.GetData(1, surface)) Then Return
    If (Not DA.GetData(2, weight)) Then Return
    If (Not DA.GetData(3, Iterations)) Then Return
    If (Not mesh.IsValid) Then Return
    If (Not surface.IsValid) Then Return
    Dim pts As New List(Of Point3d)
    Dim pts2 As New List(Of Point3d)
    Dim clist As New List(Of Vector3d)
    Dim new_mesh As New Rhino.Geometry.Mesh
    new_mesh = mesh
    Dim array() As Integer
    For j As Int32 = 0 To Iterations
        clist.Clear()
        pts.Clear()
        For i As Int32 = 0 To new_mesh.Vertices.Count - 1
            Dim pt1 As New Point3d
            pt1 = new_mesh.Vertices(i)
            intersection(pt1, surface, pts2)
            Dim pt2 As New Point3d
            pt2 = pts2(0)
            Dim vect1 As New Vector3d
            vect1 = (pt2 - pt1) * weight / 5
            array = new_mesh.Vertices.GetConnectedVertices(i)
            If array.Length > 3 Then
                Dim v1 As Vector3d, v2 As Vector3d, v3 As Vector3d, v4 As Vector3d
                Dim v_left As Point3d, v_right As Point3d, v_top As Point3d, v_bottom As Point3d
                v_bottom = new_mesh.Vertices(array(0))
                v_left = new_mesh.Vertices(array(1))
                v_right = new_mesh.Vertices(array(2))
                v_top = new_mesh.Vertices(array(3))
                v1 = pt2 - v_bottom
                v2 = pt2 - v_left
                v3 = pt2 - v_right
                v4 = pt2 - v_top
                If ((v1.X ^ 2 + v1.Y ^ 2 + v1.Z ^ 2) ^ 0.5 < (v2.X ^ 2 + v2.Y ^ 2 + v2.Z ^ 2) ^ 0.5) Then
                    clist.Add(v1)
                Else
                    clist.Add(v2)
                End If
                If ((clist(i).X ^ 2 + clist(i).Y ^ 2 + clist(i).Z ^ 2) ^ 0.5 > (v3.X ^ 2 + v3.Y ^ 2 + v3.Z ^ 2) ^ 0.5) Then
                    clist.RemoveAt(i)
                    clist.Add(v3)
                End If
                If ((clist(i).X ^ 2 + clist(i).Y ^ 2 + clist(i).Z ^ 2) ^ 0.5 > (v4.X ^ 2 + v4.Y ^ 2 + v4.Z ^ 2) ^ 0.5) Then
                    clist.RemoveAt(i)
                    clist.Add(v4)
                End If
            ElseIf array.Length = 3 Then
                Dim v_left As Point3d, v_right As Point3d, v_bottom As Point3d
                v1 = pt2 - v_bottom
                v2 = pt2 - v_left
                v3 = pt2 - v_right
                    clist.Add(v1)
                Else
                    clist.Add(v2)
                End If
                    clist.RemoveAt(i)
                    clist.Add(v3)
                End If
            Else
                v_right = new_mesh.Vertices(array(0))
                v1 = pt2 - v_right
                v2 = pt2 - v_left
                    clist.Add(v1)
                Else
                    clist.Add(v2)
                End If
            End If
            Dim vect2 As New Vector3d
            vect2 = clist(i) * weight / 150
            Dim pt3 As New Point3d()
            pt3 = pt1 + (vect1 + vect2)
            pts.Add(pt3)
            new_mesh.Vertices.SetVertex(i, pt3.X, pt3.Y, pt3.Z)
        Next
    Next
    DA.SetData(0, new_mesh)
    DA.SetData(1, clist)
    DA.SetData(2, pts)
End Sub
Protected Overrides ReadOnly Property Icon() As System.Drawing.Bitmap
    Get
        Return Nothing
    End Get
End Property
Public Overrides ReadOnly Property ComponentGuid() As Guid
    Get
        Return New Guid("{9c70ee3d-8f13-46b7-8daa-da2eb946f138}")
    End Get
End Property
Private Sub intersection(ByVal pt1 As Point3d, ByVal y As Surface, ByVal pts2 As List(Of Point3d))
    pts2.Clear()
    Dim vectl As New Vector3d(0, 0, 500000000000000)
    Dim ln As New LineCurve(pt1, vectl)
    Dim u As New Double
    Dim v As New Double
    Dim int As Intersect.CurveIntersections = Intersect.Intersection.CurveSurface(ln, y, 0.1, 0.1)
    If (int Is Nothing) Then
        y.ClosestPoint(pt1, u, v)
        pt2 = y.PointAt(u, v)
        pts2.Add(pt2)
    End If
    If (int.Count = 0) Then
        pts2.Add(pt2)
    Else
        Dim minX As Point3d = Point3d.Origin
        Dim minD As Double = Double.MaxValue
        For j As Int32 = 0 To int.Count - 1
            Dim ccEvent As Intersect.IntersectionEvent = int(j)
            Dim localD As Double = pt1.DistanceTo(ccEvent.PointA)
            If (localD < minD) Then
                minD = localD
                minX = ccEvent.PointA
            End If
            pts2.Add(minX)
        Next
    End If
End Sub
End Class
Thanks in advance for any feedback,
You have set your “weight” input to be an integer… Did you need it to be of type double?
Hey Rajaa,
Thank you for your reply. I have tried making the weight input as a double. However the only option is pManager.AddNumberParameter, which I assume contains the Double Type. That did not work either, I changed everything containing Weight as doubles as well.
Yes, pManager.AddNumberParameter is what you need to use for double.
Can you email me your project? I’ll try to debug at my end. You can email it to rajaa@mcneel.com.
