Hello, how can I add “surfaces” to my custom display mode?
And is there some way to have display mode by parent? As with colors? Exploding blocks is too much of a hassle.
Hi Vojtech -
Technical display modes do not have settings for “surfaces”, only for the lines that are created from those surfaces.
That seems to be missing → RH-83976 Properties: Display Mode Needs By Parent Setting
Note that you can sub-object select members of a block instance and then set the display mode for those members.
