I have a series of Mesh geometries with VertexColors and a custom display mode (6_ShadedDiagramatic) that I have set up since Rhino 5.
When I switch to the custom display mode, the mesh geometries are displayed incorrectly. This error is retained even if I later switch to a standard display mode (Shaded)
To recover from this, I did the following:
- Switch to standard display mode (i.e. Shaded)
- Save the model.
- Close and reopen the model, or run command
Revert
I believe this does not alter the geometry data in the Rhino file.
Question: Is there specific settings within my custom display mode that causes this ?
In the mean time, I will compare this display mode with another custom display mode to see which setting is the culprit.
RH_DisplayBug.3dm (127.6 KB)
6_Shaded_Diagramatic.ini (13.3 KB)
Expected
Incorrect
