Custom button despite save of file vanishes
V5
made a custom button, sure I saved the file later on, next day its gone, remake it, deliberately save the file, open another file and its gone again..
Grrrr
Steve
Rhino 5 is a bit hard to remamber all the issue, but here may be the problem. A few things to check:
  • Do you have more than one Rhino window open? The last one closed overwrites the .rui and drops the new button.
  • After adding the button, use Tools > Toolbar Layout > File > Save, then close Rhino normally.
  • In Toolbar Layout, what’s the path of the open .rui? If it’s default.rui under Program Files, use File > Save As to save a copy to your Documents folder and open that one instead.
