I have a series of radial cross sections for propellers. I have pute them down in series and drawn the cross ections. I have also marked the reference at the blade axis, ends of the hub face, max and min thickness.
The shapes need to be curved to an arc along the blade face then rotated around the for the pitch angle (easy).
Here I used a spreadsheet to transform the points to the desired end location and have connected them with splines to show the generally desired effect.
Is there a simple way to bend the grouped shapes and reference points to a radius?
