Curves tie up after offset
Hello there, I wonder if there is an efficient way to clean the offset curve instead of removing the additional control points or rebuilding the curve. Thank you
Take a look at the Clipper plugin.
Thank you Martin ! I will have a look of this plugin!
are you missing the
Trim = yes
option in the dialog of _offset ?
https://docs.mcneel.com/rhino/7/help/en-us/index.htm#commands/offset.htm
trim no
trim yes
Hi Tom, thank you for the reply, I think when a curve has too many control points, the trim command doesn’t always work.
doesn’t…
