Curves incomplete display
Parts of the curves are not shown completely, depending on the zoom size.
2024-10-24_CurvesDisappear.3dm (87.9 KB)
I see this in V6-V8, but V5 is good.
The curves were imported from a DXF file.
Hi, @Charles. I can confirm this is an issue related to OpenGL 3+. You can downgrade to OpenGL 2.1 in Rhino 8 to solve the problem as a workaround.
Tools > Options > View > OpenGL > Level > OpenGL 2.1, then Restart Rhino.
Let us know if that helps.
@stevefuchs it is best to make YT issues for this. Lowering OpenGL levels is not a good solution as this will reduce capabilities of Rhino in other ways.
@stevebaer Will do Done. Just trying to nail down the problem and get confirmation first. https://mcneel.myjetbrains.com/youtrack/issue/RH-84456
Is it really related to OpenGL?
I thought it is an import issue.
The offending curves are weird:
When importing the DXF in Rhino V5, the result are 3 lines.
Unfortunately, I can’t send the DXF to here, but as PM.
Hi, @Charles. It’s in our system for developer investigation, now. You can follow the progress via the YouTrack link above. If you PM or email me, I’ll add the DXF to the report. steve.fuchs@mcneel.com
NOTE: DXF sent and added to YouTrack
@stevefuchs
News on this?
Hi Charles -
As Steve wrote, you can check the status of that ticket at any time.
This is currently on the Future list.
