I may have found a bug where curves are not highlighted correctly when they are located in nested blocks and used for a loft, sweep or an extrusion There seams to be several occasions that happen when you select the curves:
Sometimes the curves are not highlighted when you select them – zooming out will highlight the entire block
Sometimes the curves are not highlighted when you select them – zooming out will highlight the curve correctly
Sometimes the entire block is highlighted when you select the curve
Curves in the next block that you want to select are already highlighted
I don’t really see a pattern when or why the curves are not highlighted correctly, except that the curves are located in nested blocks. I have uploaded a test file:
I’ve tried a few things with your file but am not seeing the behavior that you are describing.
Please run the Rhino SystemInfo command and copy-paste the result here.
Windows 10.0.18363 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro K620 (NVidia) Memory: 2GB, Driver date: 1-22-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 461.40
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-22-2021
Driver Version: 27.21.14.6140
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
Hi Peter - highlighting in nested blocks is indeed not reliable - it is a bug, or a limitation, I guess, that is known and as far as I know not currently fixable. But, here, if I can select an edge in your blocks, they do seem to highlight. I can make a nested block here where the highlight is definitely incorrect though.
Thank you for your reply. I have tried the testfile one more time this morning. Lofting the green curves will highlight the entire block, all the other curves seam to work fine (In my case).
This year I have been working on a project where I used this concept quite often. Therefore, I recognized this issue in the first place. I guess there is no way to change it for now, but it´s not as bad anyway.
