Curves change colour and become “ghosts”, and are unusable, uneditable, cannot be highlighted
Hello - are they very far from the world origin?
Hi Pascal,
This is a small model, around 100mm in size, so quite close to the origin.
I would appreciate your help as this is not the first time this has happened.
thank you
Lynton
Hi Lynton - please post the model, or send to tech@mcneel.com and someone will have a look.
…and the object and layer aren’t locked?
(long cat blink)
Hi @Lynt
Could it be that “history” and “lock children” is on? Shooting in the dark here - post a file, and I’m sure someone will figure it out
-Jakob
Hi Brenda,
Thank you for replying, no the layer neither the children are locked
Thank you Pascal,
I will send you the file when I am infront of my PC
Hi Pascal,
Here is a link to the file…
Please let me know if you need anything else.
Thank you,
Lynton
Hi Lynt - the objects are locked - use the Unlock
command, or UnlockSelected
Hi Pascal,
Thank you, that helped.The thing is that I did not purposely lock them, it seems to happen of it own accord.
It also doesn’t show them as locked in the layer window.
Do you perhaps have any suggestions for me on this issue?
-Lynton
Right click here:
If you find a reliable way of making this happen, please inform us of the necessary steps that are involved.
The layer panel only shows the status of the layer, not of individual objects.
