CurvePiping creates open meshes
Hi @pascal and @Dale,
while trying to use the results of curve piping for boolean operations i’ve found that the command creates open pipes when the input curve is closed (periodic) but not planar. An example curve is attached below.
I’ve tried to write a script to make cleaner pipes using Mesh.CreateFromCurvePipe method, but it has the same error.
CurvePipe.3dm (7.5 KB)
_
c.
Hi Clement - I see that - MatchMeshEdge for now, to close them up.
RH-63269 ExtractPipedCurve: Open meshes
Thanks ! I’ve had many and they are already muddled up.
_
c.
