I never said nurbs. The whole point of curvepiping and thickness is that you can visualize when you need it and you never have to model it. It’s a render-effect. A design-decision tool. Same as shut-lining (if it looked better).
So because there are effects and they are procedurals it would be great if they have more input options.
I think I’ve acquired them all in the last 15 years of so since I started playing with them: Maya, Max, Zbrush, Modo, Silo, 3Dcoat, sketchup, Tsplines, even tried Clayoo, Softimage, Lightwave…
But I keep coming back here to be rescued from that insanity. I think McNeel can do it better. No doubt.
It would help if the request was a bit more specific. If you would separate the “must have” from the “nice to have” - what stands out in the videos that you think is important?
Thanks David, I’ll give more though to priority, basically this is building on that earlier wish you and I discussed about having different ripe of profiles on curve-piping. I’ll find it here and will keep going. Stay tuned. G
