So now CurveLength text field formula can display surface edge lengths like so:
but can it do the same for polycurve segments? It seems to accept the segment
(picked by Ctrl + Shift + LMB), but it shows 0 length…
Hello - yeah, I see that - I suppose it ought to work properly on sub curves or not at all. The formulas look at object ids, which are top level things, so for now, using SubCrv orExtractSubCrvwith Copy=Yes, then dimension that…
This should be possible. Added to thr wishlist at
https://mcneel.myjetbrains.com/youtrack/issue/RH-64789
