Hi Gijs, I like the idea of object property panels, great idea.
On my Mac i am not seeing anything like you are showing above.
Downloaded ok, the command appears when typed, but i get this in the history box.
This list on the side is updating and does not seem to show the history anymore (line selected) once Curveinfo is activated. Needs a restart to get back to normal.
@JP13 I’ve uploaded a new version that should now display the dialog correctly. But it nowhere functions as it should, because it looses focus as soon as you type something in that dialog, so for now it is still practically useless on Mac.
I guess I need some help from bigger brains to solve this.
Hi Gijs, many thanks, the new version works well. I am learning something about the terminology, like spans, object types, degree, points etc.
I find the display seems permanent, like a floating info box (Similar as drag Strength), even when i type another command, create a line or curve etc.
The current curve selected shows 5 points, but i only count 3?
Ok, just for fun I have 3 screens in front of me, i just tried to drag the (Curveinfo) window onto a 2nd screen and it disappeared behind all. I could only see it by using the Mac F3 (show all open windows) it is still there and functioning but i could not drag it back into view without quitting and restarting.
Re the bigger brains, you’re doing great, this is waay above my pay grade, so keep it up.
Should the dialog also allow for rebuilding, simplifying and Elmoing curves? For soms reason, that seems to be an appropriate use case to me - as a diagnostics and trouble shooting tool.
I was thinking about adding a simplify option, not sure about the rebuild tools.
Although these could be started from there as well, it would not help much imo, since these commands have their own interface anyway.
But first I need to solve the annoying focus issue on Mac. I know what needs to be done for that, just haven’t gotten around to it. Some refactoring is necessary.
@JP13@Intuos I just uploaded a newer version to PackageManager that should address the issues I had with the controls loosing focus.
Thanks to @curtisw for solving.
For future reference:
If you are making a dialog, derive from Eto.Forms.FloatingDialog
Disabling controls make them loose focus.
The above is esp. important on Mac.
I’m really missing a function inside Rhino to see what’s the area or length of a object. Thanks for your plugin, it’s a nice first start. May I request some enhancements:
Options menu to hide/show parts of the panel
Count totals in area and length when you select multiple curves
Perhaps hide for example the radius value when selected multiple circles, but when you enter a value all circles get this value
Perhaps show number of selected objects
Bedankt!
Ps. what’s that nice looking function you show in video? Curve Listener?
