Curved Section Drawing
I have a curved floor plan and want to make a section cut or curved clipping plane that runs along the dashed line. It would almost be an like an unrollsrf but in a section drawing. Any suggestions appreciated.
@tenfuz, afaik rounded clipping planes.
I assume neither rounded sections exist in my logic.
We use (as you suggest) unrolled surface as an elevation in such cases.
ciao… non sono sicuro se hai bisogno questo :thinking:
Almost. I’m trying to get a section drawing. Imagine standing at the center of the circle and looking at the curved building. Similar to a panoramic image I suppose.
Yes, basically looking for a rounded clipping plane. The issue with unrolling the surface is that I’d have to do it multiple times at various section depths to get all the lines and then combine them after which may ruin the accuracy.
This applies to VisualARQ, but should work similarly with Rhino section drawings.
Something like this but it’s not as precise as I need it to be.
There is no mechanism for this. If you pull curves to a curved surface, you can get the accurate lines, but you would need to create the section from that. See what lines are hidden and which are front.
with many limitations, some bricolage but a lot of fun:
draw the curved surface that cuts the objects
draw a planar surface with the same length / height.
_FlowAlongSrf from from the curved to the Planar surface.
use a clippingplane to create the section / drawing…
Further to @Tom_P 's post, here’s a trial I previously created in response to the thread @Toni_Osterlund referenced. It shows a simplified circular building with a central stairwell and corridor. The Front [sic] view shows a circular section along the inner corridor wall, looking outward. As you can see, the hidden lines are included from a single unroll.
HTH
Jeremy
EDIT: Actually, strictly that is two unrolls: if you have a full 360 object, _FlowAlongSrf distorts. The workaround is to do two 180 unrolls and join them.
… nice sample
that also shows some fancy things happing: the walls get tapered / conic / thinner to the outside :grimacing:
resulting in some doubled hidden lines:
Yes, further out you go the more the structure is compressed by the unroll. I was pleasantly surprised by how well Rhino handled this.
This view should really have “Do not scale from this drawing (usual message) but in this case we really mean it because the only true dimensions are either in the section surface or vertical” on it. Reason I personally dislike curved sections that are not limited to the section surface.
Thank you, I think I figured it out.
Thank you!
