CurveBooleanUnion fails to produce a result for the attached input.
bu.3dm (40.5 KB)
I’m using the following python script to execute the CurveBooleanUnion command.
def Test():
crvs = rs.GetObjects("Curves", rs.filter.curve)
u = rs.CurveBooleanUnion(crvs)
if u:
rs.SelectObject(u)
else:
rs.MessageBox("Union failed")
# Check to see if this file is being executed as the "Main" python
# script instead of being used as a module by some other python script
# This allows us to use the module which ever way we want.
if __name__ == '__main__':
Test()
# NOTE: see UseModule.py sample for using this script as a module
I’ve looked at the CurveBooleanUnion code in curve.py and it seems like the underlying Rhino function must be failing to return any valid curves.
