Piotr
1
@AndyPayne
Rectangle has it starting point in lower left corner and it runs clockwise. I think domain should be reversed here.
Edit: quite strange, it fixed itself by panning the view
I think there is some minor problem with component update. It keeps the old colour even with removed swatch (should be reset to default)
How did you draw the rectangle? It looks correct here.
Why did you flip the direction?
Maybe I’m missing something but isn’t the curve direction usually counter clockwise?
This is a circle on XY with 10 perp frames:
And the same circle with the curve widget:
Piotr
5
Flipped or not, it has to be correct.
What is wrong? Are you expecting a clockwise domain?
Piotr
7
Sure, what’s wrong with that request? This is my understanding of that principle. I hope I’m not embarrassing myself here.
The second images proves it is correct.
Nothing is wrong with your request, I just asked whether you expect a clockwise domain?
Piotr
9
The correct representation (best when animated) of this idea works well with basic Gh components
