Curve visualization issue
I found a weird behaviour of a curve’s display conduit. The curve in the file is correctly added to the document, but activating a preview, for example with SoftEditCrv command, you can see that it turns into a very bad one with infinite length.
Is there maybe something I can do to build a better performing curve? I initially thought the problem was with the plug-in I develop, which produces that curve, but I did not find anything wrong.
Thanks in advance,
Emma
DisplayConduitIssue.3dm (68.4 KB)
Hey Emma, thank you, that’s a nice one :slight_smile: It also happens in the ToNurbs command.
I have created a ticket for this here: https://mcneel.myjetbrains.com/youtrack/issue/RH-99394
One thing I notice is that the bit where things go wrong is a degree 11 segment. While there are other degree 11 segments in the polycurve that do not show this problem, it seems likely that this is the cause of the problem.
While Rhino should be able to handle up to degree 11, as a workaround try to keep the degree of the curves to let’s say maximum 7 or so. Of course this problem needs to be fixed but this may help for now.
Thank you Menno for your answer!
I will use the workaround you suggest in the meanwhile.
Emma
