Curve Toolbar not showing in V6
I upgraded to v6 at the weekend. All went well but I’ve noticed that the curve toolbar that used to appear with a long press on the Control Point Curve button (in the main toolbar) no longer appears. The little grey expand triangle is still there so I assume it should show - is this a know bug and if so how do I fix it?
Thanks.
Hello - use ToolbarReset and the restart Rhino - that will reset the default toolbar - does that sort it out?
Thanks, Pascal. I actually can’t remember how I fixed it but I must’ve found a solution because it works now. It’s two years since I posted the original question - how time flies!
