Curve that fits between 2 curves?
like this:
If your rest of the curves are organized in the same fashion, then maybe it would help.
And please don’t make double post.
overlap curve perimiter offset_re.gh (11.5 KB)
Thank you,
Im trying this patch with another set of curves.
im not getting good results. what do you mean “curves are organized in the same fashion,” ?
_01 file shows the result and attached .gh file
01
_02 file shows another scenario of another merging set.
is that possible to input all curves in the first object or would this need a specific selection of each set and a copy of the whole patch ?
overlap curve perimiter offset_re_01.gh (55.6 KB)
overlap curve perimiter offset_re_02.gh (130.0 KB)
I see now it works well, just needed to turn curves parallel to C plane.
where am i suppose to change the plane orientation in the patch ?
ps
still not sure if 02 set could be done.
Hi
im thinking my curves arent of the right “type”
any idea ?
overlap curve perimiter offset_re01.gh (309.5 KB)
