Hi, I’m using build 0.9 and have an issue with the curve side component. I have checked already everything I could the tree structure and order, NULL items in a tree etc. Have no idea were I’m wrong.
So this is the picture of what i/m trying to do.
I’ve cut out all the lines from the right side and now try to delete those wichs are been untouched, for that I check whether the middle point of lines from the right or the left side of the polyline. And there always is some mistakes.
So how does this component works? What am i doing wrong? Is there another approach for that task?
Can you upload the file? Ideally internalise the polyline and the line segments you’re trying to filter so it’s as simple as possible? (i.e. point #3 in this post)
Yep there’s a bug if the point p being tested pulls onto the polyline at a corner c, and the tangent t at the corner is more than 180^{\circ} away from the vector \vec{cp}.
You can make it work for you now by adding a small fillet to the polyline you use for testing, but I’ll have to rethink the left/right testing algorithm.
I fixed the component algorithm. It should also work much better now with non-planar curves. However it’s not critical enough to risk shoving it into Rhino 6.0, so it will go out with the first service release (I don’t know when that it, but the update schedule should be way faster than in earlier versions of Rhino).
I have no way of getting you the component if you have an earlier version of Grasshopper. However I attached the file I used to test this which contains a C# script. Note that this script does not include the improved planarity tests, but it should handle kinks correctly.
I’m having an issue when using the Curve Side component in Grasshopper and it looks like a precision issue. I have a point at Y -1.8125 that is saying it is on the left side (-1) of a line (also at Y -1.8125) instead of being coincident (0). When I check the actual number the Y of the line is -1.812500000000003. This is why it is saying the point is on the left I. How can I round the number or lower the precision of the Curve Side component so that it will calculate the point correctly?
