Curve selfselection annoying
Hi…,
when I create a polyline and want to grab single lines for positional adjustment, the first movement is good, but selecting the second line brings up the annoying selection window.
Rhino_6_SelfSelection_Annoying
Can you improve this?
Thanks
Michael
www.flexiCAD.com
Hi Michael - you can control this from Options > Mouse page. Either turn off the automatic points on for selected curves and annotations, or turn off the ‘Make control polygon pickable’ Or both…
Any better?
Hi Pascal,
thank you very much, this helps a lot
Michael
Personally, I like the pickable control polygon to be enabled (mostly for dealing with surface points):
  • click on the polygon segment, you select both points
  • double-click on the polygon segment and the entire row is selected.
but I find that the auto-points-on drives me a little nuts…
