I have 62 grouper open curve, but I would like to make it a single object to use the ‘sweep’ function. Thank you.
Hello- you may need to Join the curves first, or use the ChainEdges option in Sweep1
Hello- you can use the ‘Add Slash’ in Sweep2 button to straighten the isocurves.
dear @pou010 Luc
if the shape / cross section of the surface is a constant circle - check out the _pipe command.
if the shape / cross section does not change - maybe a _sweep1 (one rail) is enough - using a road like direction of 0,0,1 (z-direction) …
if you need more help - please post the file.
kind regards -tom
the initial starting section should not change, but may change if the distance between the two curves varies. but I ‘lost’ my objects I am looking for the command to re-center my objects in each view. Thank you.
_zoom _all _extents
thank you, thank you, thank you
