To reduce the clutter on my Grasshopper project, I thought I would attempt to make a Curve Midpoint Cluster, but I cannot seem to get it working.
I’ve tried adding a point on the output, as well as deconstructing and then reconstructing the point, but I still get red and no midpoint. I’ve tried setting the internal N and I variables, but it still goes red.
There’s only a few components, but I am seeing at least 12 of these groupings in my project. It’s more of a readability thing.
Any idea would be appreciated, thank you,
–BrendaEM
BTW, that component was one of the only underwhelming Grasshopper components I have found. I wish it were redone, so a slider ( and the curve to be divided ) could be attached to the front of it.
And, visually, It appears like a much earlier version, compared to the rest of the components.
It worked as you uploaded, but when I pasted it in, it was displeased.
I restarted and it works fine.
Thank you. : )
For now, I am calling it: “Mid” .
I used it 13 times in the same project. It was gratifying to do replacements because it replaces a little more than it seems. The point order changed a bit in my project, which wasn’t so gratification, but I just need to comb out the tangles.
[ In the screenshot, the grouping just displays the angle of a windshield that the rest of the group creates. ]
