Hi all,
Trying to dimension the edges of a curved object in layouts in rh8 mac.
Ideally, I’d like to use two curves in one text field – we’re cutting a rectangle out of kerfcore, and I want to show the cut dimensions, like this: 3/4" KERFCORE: 45-3/4" x 76-13/16"
Here’s the problem:
If I do DimCurveLength, each individual one works fine.
When I try to edit the leader, the fractional component pops out of the formula, like this:
%<CurveLength("d1a7b1df-73f6-44ba-8b1d-20e9f43f262c:2,12")>%[[3/4]]
When I try to use the same formula in a text field (because I want both dims in one leader), it converts inexplicably to decimal.
I can meticulously do each individual DimCurveLength, then copy one into the other, then delete the extra fractions, then add " markers, but this is a LOT of work for one little dimension leader.
Including a screenshot showing all these possibilities. Here’s the text field for the upper left one (after copy pasting, each time the fraction replicates itself):
[[3/4]]" KERFCORE:
%<CurveLength("d1a7b1df-73f6-44ba-8b1d-20e9f43f262c:2,12")>%[[3/4]][[3/4]] x %<CurveLength("9eef5374-7c80-4f80-8715-84f97e33bf76:2,7")>%[[13/16]][[13/16]]
Here’s the one for the upper right:
[[3/4]]" KERFCORE:
%<CurveLength("d1a7b1df-73f6-44ba-8b1d-20e9f43f262c:2,12")>% x %<CurveLength("9eef5374-7c80-4f80-8715-84f97e33bf76:2,7")>%
