Curve interval
Dale,
When calling “ON_Interval rnCurveInterval = prnCurve->Domain();”, we want to make sure “rnCurveInterval.m_t[1] > rnCurveInterval.m_t[0]”. Would switching the two values work? (The curve may be periodic, so switching the two values may not get the right interval.)
@XNurbs, in RhinoCommon there is an Interval.MakeIncreasing() method, not sure if this helps.
_
c.
Hi @XNurbs,
You can use ON_Interval::IsIncreasing to test if ON_Interval::m_t[0] < ON_Interval::m_t[1].
To safely swap ON_Interval::m_t[0] and ON_Interval::m_t[1], use ON_Interval::MakeIncreasing.
– Dale
Dale,
We change the code to
rnCurveInterval.MakeIncreasing();
Would it ensure (rnCurveInterval.m_t[1] > rnCurveInterval.m_t[0])? or still need to swap ON_Interval::m_t[0] and ON_Interval::m_t[1]?
ON_Interval::MakeIncreasing says “returns true if resulting interval IsIncreasing()”. If it returns false, then what?
Many thanks.
ON_Interval::MakeIncreasing ensures the interval is increasing. If the interval is already in creasing, then nothing is done.
– Dale
