Curve intersection fail?
Why doesn’t this curve intersection work?
Could it be due to the angle tolerance? Is there any way to obtain the correct result?
CurveIntersection.gh (2.9 KB)
looks indeed like a Tolerance thing:
Seems to be unit tolerance rather than angle tolerance - I increased the tolerance to 4 decimal places and it calculated correctly - Options >Units >Absolute Tolerance
But it does seem a bit odd, because they’re 0.5 units off
Thanks @Artstep & @inno
Is there any way to avoid that issue without changing the drawing settings? I need to implement this method using Rhino.Compute.
Maybe using C#…
I think most intersection commands have a tolerance input anyway https://developer.rhino3d.com/api/rhinocommon/rhino.geometry.intersect.intersection/curvecurve
But with a tolerance of 0.01, a deviation of 0.49 seems a bit too significant - the lower tolerance can lead to much slower calculation times depending on how much geometry you’re processing though
Hi @Alfredo_Peña,
This works.
–Dale
It doesn’t work for me either
