Curve draw order ignored if BLACK?
Hi Pascal, can you take a look at this?
If the top layer is black (0,0,0) then the curve on the red layer is drawn on top:
But if I change from black to superdark gray then it is as expected:
Even odder: If I only set G or B to 1 then it draws on top, but if I only set R to 1 then it doesn’t…
Hm - I see that, I have no idea how that is decided… I’ll add it to the pile.
But the behavior seems it falls apart when object color is changed as well - here, it did not revert when I changed colors back to use the layer.
