Hello All
Wondering if someone here has run into this issue - hoping there is a quick fix…
I am doing some drafting in Rhino 5 and wish to use multiple files to separate different drawing elements. I intend on inserting these files into ‘sheet files’ to create various drawings. When I link one of my files some of the 2d geometry doesn’t appear in the main (sheet) file however when I select the link/block I can see the missing geometry.
Unselected the link/block looks like this.
Please see bottom right of plan for an example of where the curves are not displayed
When selected the link/block looks like this.
I have checked this in Rhino 7 and there is no issue. Unfortunately I don’t have a Rhino 7 licence…
I have uninstalled and reinstalled Rhino 5.
Attached are the main and linked files.
MAIN FILE.3dm (57.7 KB)
LINKED FILE.3dm (234.4 KB)
I should add that the issue is persistent when printing to PDF.
Thanks for reading if you made it this far.
