Hello everyone,
I am trying to panelize a quite organic surface with 1m x 1.65m panels. I made a set of transverse curves, 1m apart from one other and some longitudinal curves, 1.65m apart. Both sets of curves are on the surface that I created, so I intersected them to get all the vertexes in order to create the 1x1.65 panels. However, it seems that some of the vertexes are missing. I attached an image below with the problem.
I thought that maybe the curves do not intersect after all, so I projected the lines on the surface and used the curve-curve intersection tool again. This time it was even worse, more of the vertexes were missing.
I attached the rhino and grasshopper file if you want to take a look. I included a remap tool that was necessary to define the shape of the surface, so I attached also that. I appreciate any suggestion you can give me!!! Thank you in advace
Remap .ghuser (5.3 KB)
17102018_Panelizing.gh (47.6 KB)
17102018_Panelizing.3dm (25.3 KB)
