Curve.Contains help on understanding result
Hi guys, this feels very noob, but how do I understand the result from the Curve.Contains command?
Right now I convert the result to a string and then checks that, but that doesn’t “feel” right.
import Rhino
curve_id=rs.GetObject("",rs.filter.curve)
if curve_id:
    curve=rs.coercecurve(curve_id)
    pts=rs.GetPoints()
    if pts:
        for pt in pts:
            test= curve.Contains(testPoint=pt)
            if str(test) == "Inside": print "Inside"
You get back an enum
if test == Rhino.Geometry.PointContainment.Inside: print "Inside"
:expressionless: that world is soo abstract… I found the page
https://developer.rhino3d.com/api/RhinoCommon/html/T_Rhino_Geometry_PointContainment.htm
but it made no sense until I saw your example, so THANK YOU AGAN!!!
