Curve connectivity to points
Hello, I need to check if these curves are connected to the given 51 points.
Result should be True and False and should return only for the given 51 points.
Let me know.
Point to Curves.gh (7.5 KB)
none of your points lie on any curve
but here’s the method
Point to Curves [fixed] .gh (12.8 KB)
the logic is this:
  1. it finds which point is the closest to the middle of each curve
  2. calculates the minimum distance between that found point to the curve
  3. if that distance is smaller than a tolerance (close to zero) it outputs true, else it outputs false
