Such a useful tool. Seems odd there’s no option for output layer. First selected, last selected, a mechanism to choose existing, new layer?
output layer is current layer - the default behaviour if you generate new geometry for most commands.
Hi Tomp,
Sure, I get that. But, considering, at least in my use cases, Curve Boolean often receives input from curves that were intentionally placed on a layer other than the current layer, it feels like a missed opportunity in a productivity sense not provide a means with which to place those output curves on the same layer as the input curves. I know this functionality existing within other commands. Not advocating for this to be mandatory or default behavior.
Typing SetLayerToObject before using Boolean takes just as much time as ticking a box in a pop out menu. Especially if you have an alias set for it - for example SLO.
I suppose you’re correct if you don’t take into account the need to then switch back (if you remember) to the originally selected layer after the operation. This could all be obviated by a sticky option within the Boolean command. Anyway, I appreciate the input and suggestion. This was just me offering a little insight into a particular use case and how it might be streamlined. Always more than one way to skin a cat.
