I’m trying to understand the exact meaning of the output of the Curve.FrameAt and Surface.FrameAt methods. Both return planes - what do these planes represent?
A quick google of the term curve frame yields the Frenet Frame: https://en.wikipedia.org/wiki/Differential_geometry_of_curves#Frenet_frame
Which I know as the moving trihedron of a curve, which could be expressed as a set of 3 vectors.
I’m guessing here, but as the Curve.FrameAt function returns a plane, is it returning the plane constructed from the unit principal normal vector and unit binormal vector? This plane + the Curve.TangentAt method would give enough information to construct the trihedron/Frenet Frame. Alternatively Curve.FrameAt(t).Normal would give the same as the tangent if I am correct.
Similarly for the Surface.FrameAt function, does the plane it returns represent the tangent plane to the surface at that point?
Thanks in advance.
