Does curvaturegraph no longer work on surfaces? Maybe there is a separate command now?
One thing we’ve always wished is for separate scales for U and V directions.
Thanks,
Eric
Thanks,
Eric
that should still work, at least it does here. If it doesn’t at your end, pls post your _SystemInfo
It looks like I have something else going on, curvaturgraph works as expected if I pre-select a surface. I can’t select a surface after issuing the command.
