That does sound strange. Could you please share the 3DM file with us so we can take a closer look and check whether this could be a bug?
Thank you!
villa s.3dm (12.6 MB) it seems like every time im trying to make curved panels the curtain wall is always going to miss even one mullion for some reason. Using the default style is also doing the same thing even when I create a new file, the same problem occurs. I was following an older tutorial from the offical website and I am doing exaclty the same steps but it doesnt seem to change anything. Tell me if im doing something wrong. Thanks
It looks like this might be a bug in an older version of VisualARQ.
Could you please install the latest VisualARQ 3.12 RC1 version from here?
After installing it, select the curtain walls and run the VAUpdate command. They should update correctly and the missing mullions should appear.
Please let me know if you still have any issues after updating.
Best,
Melissa
