Cursor type change from RhinoCommon sample?
Hi All,
Does anyone have experience with changing the look of the cursor via scripting? (Python + RhinoCommon). For now I am interested in the Rhino built-in types like the zoom/pan/rotate view navigation symbols that replace the arrow cursor on view navigation, or a crosshair when drawing…
Thanks for any suggestion.
–jarek
Yes I did this before, I’ll see if I can dig up an example
You change it through Rhino.UI.CursorStyle:
https://developer.rhino3d.com/api/RhinoCommon/html/T_Rhino_UI_CursorStyle.htm
example is when using GetPoint: (example from https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Input_Custom_GetPoint__ctor.htm with added cursor code)
import Rhino
import scriptcontext
import System.Guid
def AddLine():
    gp = Rhino.Input.Custom.GetPoint()
    gp.SetCommandPrompt("Start of line")
    gp.Get()
    if gp.CommandResult()!=Rhino.Commands.Result.Success:
        return gp.CommandResult()
    pt_start = gp.Point()
    gp.SetCommandPrompt("End of line")
    gp.SetBasePoint(pt_start, False)
    gp.DrawLineFromPoint(pt_start, True)
    gp.SetCursor(Rhino.UI.CursorStyle.Magnify)
    gp.Get()
    if gp.CommandResult() != Rhino.Commands.Result.Success:
    pt_end = gp.Point()
    v = pt_end - pt_start
    if v.IsTiny(Rhino.RhinoMath.ZeroTolerance):
        return Rhino.Commands.Result.Nothing
    id = scriptcontext.doc.Objects.AddLine(pt_start, pt_end)
    if id!=System.Guid.Empty:
        scriptcontext.doc.Views.Redraw()
        return Rhino.Commands.Result.Success
    return Rhino.Commands.Result.Failure
if __name__=="__main__":
    AddLine()
thanks Gijs, this is interesting and the sample works well.
In the docs I can only find the .SetCursor being available for GetPoint or GetTransform.
What if I just wanted to change the cursor independently of any “getters”? Say:
  1. Print something
  2. Change cursor
  3. Wait
  4. Print something else
  5. Change cursor back
Is that currently possible ?
thanks!
–jarek
I figured out how to do it using System cursors; would it be possible to use the cursors available in Rhino in a similar way?
from System.Windows.Forms import Cursor, Cursors
# Turn on the waiting or busy cursor symbol
Cursor.Current = Cursors.WaitCursor
rs.Sleep(1000)
Cursor.Current = Cursors.Hand
rs.Sleep(1000)
# reset cursor
Cursor.Current = Cursors.Default
thanks!
–jarek
Yes I think that’s the only way afaik
