Rhino ver 6 sr16
Windows 10
Problems began with sr16 update
Object selection is offset from cursor. Must zoom in tight to select objects, even large objects with no or few other objects onscreen. Also cannot directly select Gumball handles, must select from open space slightly away from handle.
Snap Radius set to default 15
Digitizer Snap Radius set to default 1.0
Working perfectly in Rhino 5 and latest WIP
Reinstalled ver6 sr16 twice
Same behavior with mouse or stylus
File size has no effect
Same results in a new file.
Wireframe objects select correctly but Gumball handle selection is “offset”
All other shade type views have the same “offset” result
There is an updated NVIDIA driver that I was unable to use due to conflict
Rolled back to previous version weeks before loading Rhino 6 Sr16
System Info:
Rhino 6 SR16 2019-7-9 (Rhino 6, 6.16.19190.07001, Git hash:master @ a8b4ee102e9e0eb1d11825df063e13f96d518f93)
License type: Commercial, build 2019-07-09
License details: Cloud Zoo. In use by: ME ()
Windows 10.0 SR0.0 or greater (Physical RAM: 40Gb)
Machine name: GREENROOM
John thank you again.
I have to do this later, I cannot risk a problem while “on the clock.” Last time the GeForce driver update caused some issues.
I will post an update Monday.
Finally had a moment to install the updates.
Object & Gumball selection is back to normal.
Thank You Thank You Thank You!
Also a huge thanks for the direct link to the appropriate drivers, seems impossible to locate the GeForce driver without signing up for an NVIDIA account that has requirements I cannot fulfill.
