Cursor is "off" when selecting Objects
Rhino 6 SR24 2020-2-24 (Rhino 6, 6.24.20055.18581, Git hash:master @ 50da88420aeefa029340da577d5cf9bfc5e22076)
License type: Educational, build 2020-02-24
License details: Cloud Zoo. In use by: Kevin Cheung ()
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: DESKTOP-LEHYWHI
Non-hybrid graphics.
Primary display and OpenGL: AMD Radeon RX 5700 XT (AMD) Memory: 8GB, Driver date: 1-24-2020 (M-D-Y). OpenGL Ver: 4.6.13587 Compatibility Profile Context 20.1.4 26.20.15017.1005
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 1-24-2020
Driver Version: 26.20.15017.1005
Z-Buffer depth: 24 bits
Total Video Memory: 8176 MB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.24.20055.18581
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Users\Kevin C\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\ProRender (2aae3eb3-985b-4e64-b19a-fed69ef9dfeb)\2018.1.18.804\ProRender\ProRender.rhp “ProRender”
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.24.20055.18581
C:\Users\Kevin C\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\PanelingTools (6caed836-bc06-4ebc-b1fd-e10886a0dc94)\2018.12.17.906\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.24.20055.18581
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.24.20055.18581
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros 6\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\KeyShot9RhinoPlugin (ecfe8d1f-876a-460f-aa5e-3dd816936811)\1.0.0.0\KeyShot9RhinoPlugin\Rhino 5.0\KeyShot9RhinoPlugin.rhp “KeyShot9RhinoPlugin” 1.0.0.0
C:\Program Files\Rhino 6\Plug-ins\Squish.rhp “Squish”
When selecting Objects anything around a 0.5-1" Radis (On my screen) triggers the selection of said object. It gets really tedious and annoying when I have complex pieces as I usually have to zoom in to select specific pieces. This also is an issue with gumball. My cursor can be an inch away from the arrows and I will still be able to select the arrows.
This issue occurs on all files that is opened with Rhino 6 however it is not an issue with Rhino WIP. I want to keep using Rhino 6.
Any help? I have attached a screenshot showing how far my mouse is from the object.
Hello - please try this: open Options > Advanced and in the search box at the top type in “PickBox”. In the filtered view you should see a number for MousePickBoxRadius - what is that? 7 or 10 is ‘normal’.
Wow,
That was the issue. It seems like I accidentally set it to 30.
Thank you so much, I have been working like this for the last 2 months.
Hello - this is actually the third report that I am aware of where this number is being set to 30. If you see this happen again, please don’t fix it immediately - instead, please disable all of the third party rendering plug-ins - I see you have several - in Options > Plug-ins page, and then close and reopen Rhino. Does that change anything? (Then fix it…)
