Hello - is this still after a while of running Rhino or is it repeatable if the NamedCPlane
part is included?
part is included?
If I open a new instance of Rhino, create some basic cube volumes, snap a c-plane to an object and save that c-plane, then the bug instantly appears and will stay until the file is closed. If I reopen the file the bug will appear after the saved c-plane is selected. Here is file see if you see. Phil
Cursor-Cplane-bug.3dm (37.7 KB)
More info, the bug only appears if I use the mouse to select the C-plane in the window. If I select with the Named CPlanes box the bug does not appear.
I will back out to 6.13 and test - this feels a lot like a bug that I did see and that has been fixed (I think), also about cursors and named CPlanes.
I’m guessing, for now, it is the same bug and it is fixed -
https://mcneel.myjetbrains.com/youtrack/issue/RH-51679
OK well at least I’ve identified my own work around for now.
