Greetings,
I have been doing some work with details and I think I have found a bug. I am attempting to use the Layout string and Detail string to change the properties of a detail. Here is the code I am using to get the detail guid from the two strings:
ID=rs.CurrentDetail("DRAWING","Top",False)
print "Detail GUID: "+str(ID)
This works fine and prints:
Detail GUID: 5fe3178e-9134-4fa7-8cb2-195e599e689a
However, when I attempt to check/change the properties of the identified detail like so:
print rs.DetailLock(ID)
I get the following error message:
Message: ‘module’ object has no attribute ‘errohandler’
Traceback:
line 188, in DetailLock, "C:\Users\BVTC\AppData\Roaming\McNeel\Rhinoceros\5.0\Plug-ins\IronPython (814d908a-e25c-493d-97e9-ee3861957f49)\settings\lib\rhinoscript\view.py"
line 6, in , “C:\Users\BVTC\AppData\Local\Temp\TempScript.py”
However, if I call the rs.CurrentDetail() function twice like so:
ID=rs.CurrentDetail("DRAWING",None,False)
Everything works fine, and it prints:
Detail GUID: 047ebe3e-2b0e-4ab2-8b2c-aab005e252e4
True
It would be nice if there were some way for me to do this without having to call rs.CurrentDetail() twice. If anyone knows of a more efficient way to accomplish I would be very appreciative.
Thanks,
5chmidt
