how wd I cull/split the list into Parimeter points and the rest ?
thnx !
oh great!
just curious, why do you use Data node coming out of the grid ?
big thanks!
So I can see the points when I was making the definition, otherwise the points output is hidden by default (you can only see the grid cells when the grid component preview is on). Data parameters like any param don’t perform any function, they are just containers usually used for organization of the definition.
gotcha ! thnx again !
