I need a little help to cull some tricky items from a data tree.
In specific I need to delete all the item of a branch data, conteining a specific text (per. example {28}) and all the branch data conteining per example only one item in the list.
I try with cull patter, but don´t work with this art of search.
Is this possible with the native GH components? any advice?
Both Text and Pattern inputs are as item, which means if you provide lists in both entries, the component will try to match the first pattern to the first text, then the second pattern to the second text, and so on.
If you really need multiple pattern to be tested on each item, you have to graft your Text input.
