Unexpectedly, the ctrl-Z, ctrl-S, ctrl-P commands have stopped working in my Rhino for Windows. Ctrl-A and crtl-I still work. I have restarted my computer and this did not fix the issue. Does anyone have any ideas of what might have caused this, or how to fix it?
Hi emmapf - first check Options > Keyboard to make sure the shortcuts are set up as you expect. Are you running any plug-ins? If so, and the shortcuts appear correct, try starting Rhino in safe mode. https://wiki.mcneel.com/developer/safemode
HI,
From some time i found that some of my shortcuts have issue (especially: Ctrl+z, Ctrl+y), when i try to do shortcuts more than one time it happens that instead to run asigned command it write the letter on the command line ( in case of ctrl+z it write Z on command line).
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1070 Ti (NVidia) Memory: 8GB, Driver date: 10-26-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.47
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPUâs maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-26-2021
Driver Version: 30.0.14.7247
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\Samuele\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp âElefrontPropertiesâ 1.0.0.0
C:\Users\Samuele\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.6.4\IntelDenoiser.Windows.rhp âIntelDenoiser.Windowsâ 0.6.4.0
C:\Users\Samuele\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.2\NVIDIADenoiser.Windows.rhp âNVIDIADenoiser.Windowsâ 0.4.2.0
C:\Users\Samuele\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\raytraced-materials\0.1.5+v7.4\RaytracedMaterials.rhp âRaytraced Materialsâ 0.1.5.0
C:\Users\Samuele\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SubstanceImporter\2.0.2\Substance.Win.rhp âSubstanceImporterâ 2.0.2.0
Thats got to be either that your keyboard is physically dying, or you have accidentally enabled(which is quite possible to do while failing around with view manipulations)some Windows âaccessibilityâ feature that changes the way those buttons work. Or another program is âstealingâ those keypresses, as Adobe products used to do with the ESC key.
